Damage if battery for a k100 connected up the wrong way
what happens if i connect up the battery up the wrong way and how do i fix it - thankyou
firemansam987 tough one to narrow down. Usually you’d fry the rectifier in your charging circuit, the battery may get damaged and the electronics may get fried as well. Check all of your fuses and see what those show. To be more specific we would need to know what it does or does not do.
这个答案有帮助吗?
Alternator or rectifier might be damaged.
Check fuses first… maybe you’ve been lucky.
这个答案有帮助吗?
where are the fuses?
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 62
