跳转到主内容
加入维修社区 - 创建账户
Afterglow Prismatic 有线手柄发布于 2015 年 10 月 25 日,是由电子游戏配件公司 PDP 生产的一款 Xbox One 手柄。
Not Turning on at all
No matter what i do, it will not turn on what so ever, i’ve tried to cord, works, i’ve tried undoing updates on the xbox, nothing. When i plug it in the light above home button flickers and still nothing. When i hold the bottom dpad the light stays on, and starts turning off and on again, but led’s arnt turning on and i cant do anything. I desperatly need help.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
I recommend getting another controller and seeing if that works. You could just be one of the unluckier folks and have a factory defect controller. If the new controller doesnt work as well, then try using a different USB port. Sometimes the connection in the USB connectors can be a little funky. If all else fails, just use a different (OEM) controller.
这个答案有帮助吗?
得分 0
添加一条评论
It's the controllers micro USB port.
I sprayed some electrical component cleaner in it, plugged it in and unplugged it multiple times (to get the cleaner to penetrate and clean the contacts) then wiggled the cord end at the port a few times, started working again.
I've even unplugged and plugged it back multiple times, works like a dream.
Hope this helps someone else!
这个答案有帮助吗?
得分 0
添加一条评论
I have this controller too,
Try wrapping the wire around the front of the controller (over the home button then down) two times
This may work but it may not at the same time
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ben Gaming 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 37
总计 2,350
