跳转到主内容
加入维修社区 - 创建账户
TI-89 Titanium 是一款由 Texas Instruments (TI) 开发并于 2004 年发布的图形计算器。TI-89 系列计算器包含一个计算机代数系统,可以对代数表达式进行符号运算。
missing horizontal pixels on display screen
I have two missing horizontal lines of pixels. The first is just below the tool bar and the second is almost half way down the screen. I ran the self test for the calculator and confirmed that the lines were missing. Is this a hardware problem or software problem. How can I determine which it is. If it is a software problem will a reset fix it without removing the factory installed programs. But if it is a hardware problem would this be an easy fix.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Hi this sounds like a hardware problem. Unfortunately, unlike the TI 83 and TI 84 lineup, the TI 89 ti doesn’t have a standard ribbon cable you can fix, instead TI attached everything to one piece making it nearly impossible to fix yourself. Even the most skilled calculator enthusiasts I know haven’t been able to repair a TI 89 ti display. :(
I’m sorry I wasn’t able to help you repair it, however if you have any other questions I’ll be happy to answer them.
这个答案有帮助吗?
得分 1
添加一条评论
https://www.cemetech.net/forum/viewtopic...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Lawrence Dunbar 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 35
总计 2,027
