跳转到主内容
加入维修社区 - 创建账户
Nintendo DS 的后继机种 Nintendo DS Lite 于2006年发布。这款设备的拆解和维修十分简单。
No Power At All
Hi, I have a Nintendo DS Lite that won't power up nor indicate when charger is plugged in to be charging or that it recognizes that the charger is plugged in. Help any suggestions on what to change? Maybe the battery? I realized the other guys here who had the same problem at least got some sort of light when charger was plugged in, but I got none at all.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
Thanks alot i will give that a those options a try.
完成的
添加一条评论
1个答案
已选择的解决方案
Make sure that your charger works. Get a multimeter and check it out. Check your battery with a multimeter and make sure it is at holding some kind of charge. Take a look at all the connections from the battery and the AC charger. Make sure they are not bend, broken or corroded. Check the F1 and F2 Fuses. Here is a video that can help you with the repair. The fuses are available here, as a set. for any further teardown and guides check here. good Luck and let us know if this helps.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Corderro Lightbourne 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 2,411
