跳转到主内容
浏览一系列食品降温用电器的维修和拆卸指南。此处是电冰箱、冷柜和其他制冷设备排障和维修的指南集合。 不管您是需要处理常见问题,还是需要特定型号设备的维修步骤,此处的指南覆盖了所有可以保持电器正常使用的主题。不管是对DIY爱好者还是专业维修技师都会有所帮助。
refridgerator not cooling still
Have a Kenmore Elite  795.74015.411
repair guy came replaced ice maker, fan motor, defrost sensor, control board, door switch
said it was all working    this was yesterday     and waited 3 weeks for parts
re set the temp on freezer to 1   fridge to 34   looked ok
now today  still no cooling and the RF error code is  now on.  But the fan and control board were replaced ??    he just came and said now it must need Freon
is that  even possible, that with all new parts replaced    any ideas besides find a new repairman as to what else could be wrong  ???
luckily this was all done under a home warranty, so I have only paid $75
but about $200 in ice over the last 3 weeks
any help is appreciated
chris
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
5条评论:
Maybe he didn't close one or more canalisations screws well, or he didn't put some Teflon tape roll or other special tape to prevent gas from escaping.
完成的
thank you will check all the screws, would not surprise me if it was something so simple appreciate the input
完成的
Hey Chris. Could it need freon in addition to other repairs? Well sure it could. But "it must need freon" coming from a refrigerator repairman sounds odd. They are equipped to test the pressure and determine if the pressure is correct or not. I would've expected a definitive statement on this aspect.
I'm also trying to imagine what symptoms led a repairman to go off in all these directions AND actually find all these things needing replacing. Maybe it's just me but the whole thing just sounds kind of strange. One would have to know a little more background info, I guess.
If I follow my instincts here, I'd say you may want to consider replacing the repairman, next.
完成的
Tony,
you are correct about get a new repair man. My original complaint was ice maker not working, and no cooling in fridge or freezer. The home warranty company sent a second guy from another appliance company to check things out.
I gave him the list of all the parts replaced. Took him 15 min to figure out it had a bad compressor, which apparently is very common in the newer Kenmore units. He thought that probably nothing but the ice maker needed to be replaced. They ordered a new compressor and finally its supposed to be here this Thursday to be installed. Luckily all of this only cost me the one time $75 service call fee, but the $250 of ice for 8 weeks is killing me. In fact gotta go get a bag right now if I want a cocktail...and I do
完成的
Hey chris. That's a lot of ice. Never once thought of having to include an ice expense in a budget. Anyway, sounds like you're on your way to being ice independent again, soon. And that's a good deal on swapping out the compressor, too. Enjoy that cocktail, friend.
完成的
添加一条评论
1个答案
Check the Freon, maybe it is just out of Freon and you need to add, if your refrigerator uses this and if it is legal to use in your country.
Cheers.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
chris 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 106
