跳转到主内容
Apple Watch Series 2, announced September 7th, 2016 and released September 16 2016.
20 个问题 查看全部
Why it's impossible to connect Apple watch and iPhone
Hello I want to know which piece is use to twinnig apple watch and iphone . It’s impossible to connect my apple watch with any Iphone . I thinks there is a piece inside who are broke can you help me please ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
The AppleWatch connects to your iPhone over Bluetooth. There is no wired link between the two.
You will also need an Apple Watch charging base if you don’t already have one which you plug into the iPhone/iPad charger or your systems USB port to gain power.
References:
这个答案有帮助吗?
得分 2
4条评论:
the bluetooth doesn't work ! i have the magnetic charger
完成的
Open the AppleWatch settings > Make sure Bluetooth is enabled. Then open your iPhones Bluetooth settings does your AppleWatch show up there?
完成的
Yes It show on my iphone but the connection doesn't work
完成的
Are you using the Watch App on your iPhone?
You may need to do a hard reset Restart Apple Watch and re-join your watch to your iPhone Set up your Apple Watch
完成的
添加一条评论
添加你的答案
dossiguignan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 78
