跳转到主内容
Guides and repair information for the LG Exalt VN220. The LG Exalt VN220 (also called the LG Exalt or Exalt LTE) is a flip phone released in 2018.
20 个问题 查看全部
Is there a repair or replacement for the hinge?
The hinge on one side has broken, and the other side is starting to really crack. Is there a repair or replacement for this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
1条评论
do i need to get a new part?
完成的
添加一条评论
5个答案
最有帮助的答案
This would happen to our flip phone, but a much older model. I would buy the same model for parts and swap the pieces that I needed. Usually, I would find my replacements on eBay. If it's out of warranty, that would be the easiest thing to do.
这个答案有帮助吗?
得分 2
1条评论:
take off front plastic with blow dryer then take off 5 screws then take out careful the screen and take it out remove the bottom 6 screws need to have to get hinge good in the phone you must have phone open when you click it in
完成的
添加一条评论
这个答案有帮助吗?
得分 1
4条评论:
What's the best way to get it clicked in?
I feel like I'm breaking it
完成的
What are you trying to click in?
完成的
The top and bottom
完成的
@meinyosele Keep the device open on a flat surface and push in the hinge.
完成的
添加一条评论
You'll want to buy a new lower Hinge, you can buy one on eBay for less than $20 shipped.
Something like this. Under $20
Side note; Make sure to transfer the old metal bracket and metal grounding tab to your new hinge that way you still have oem small parts and a tight snug fitting bracket. The Aftermarket small little parts on the hinges aren't as good as the old small parts so take off those two little parts and transfer them.
这个答案有帮助吗?
得分 1
添加一条评论
Yes, there is a website called primephoneusa.com. They have all the parts for this phone.
这个答案有帮助吗?
得分 0
添加一条评论
Check whether the hinge got any rust on it - then spray WD-40, if the hinge has become too tight need to replace with new one.
这个答案有帮助吗?
得分 0
1条评论:
I'm not sure where you got that idea from, but I would not spray any WD-40 on that device, as small as it is you would just potentially ruin some of the microchips on the PCB board.
There shouldn't be any rust building up on the hinge. If there is any dirt or anything of that sort, you can simply remove that bracket or the little pin hinge and clean it with an alcohol wipe.
Most of the hinge body is plastic, so you shouldn't be having any rust.
Ironically, I never had it where someone had a too tight of a hinge. It's most often where the hinge becomes loose. Let alone you don't want the phone flinging open because of some lubricant. Lastly, who wants to smell that every time you make a phone call.
完成的
添加一条评论
添加你的答案
Reed Edwards 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 15
总计 2,059
