Can you change/expand the memory on the Huawei Matebook x Pro?
The question is simple as the title. How easy is it to change the memory on the Matebook, and how would one do it if possible?
Hi,
Don’t know the answer but here’s a video that shows the teardown of the laptop.
It appears that the memory is mounted directly onto the motherboard. (4 chips just below the CPU). The SSD (LITE-ON brand), is on the lower left side when viewing the video .
I don’t think that it would be a very easy task to increase the memory. You’d have to unsolder the chips and then source and replace them with 4 physically and electrically compatible larger capacity chips. Also don’t know what software may have to be changed to detect the increased memory.
这个答案有帮助吗?
Quantum Leap looks like Huawei is following others. The memory is soldered to the board. So what you buy is what you get.
这个答案有帮助吗?
过去的24小时: 4
过去的7天: 23
过去的30天: 149
总计 15,172
