跳转到主内容
Laptops made by the Chinese company Huawei.
27 个问题 查看全部
Can you change/expand the memory on the Huawei Matebook x Pro?
The question is simple as the title. How easy is it to change the memory on the Matebook, and how would one do it if possible?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
已选择的解决方案
Hi,
Don’t know the answer but here’s a video that shows the teardown of the laptop.
It appears that the memory is mounted directly onto the motherboard. (4 chips just below the CPU). The SSD (LITE-ON brand), is on the lower left side when viewing the video .
I don’t think that it would be a very easy task to increase the memory. You’d have to unsolder the chips and then source and replace them with 4 physically and electrically compatible larger capacity chips. Also don’t know what software may have to be changed to detect the increased memory.
这个答案有帮助吗?
得分 5
添加一条评论
Quantum Leap  looks like Huawei is following others. The memory is soldered to the board. So what you buy is what you get.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Quantum Leap 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 25
过去 30 天: 136
总计 17,002
