跳转到主内容
Xbox One 手柄在2016年随着 Xbox One S 的推出而问世,并增加了对 Windows 10/11 的蓝牙支持。 该手柄修复了 Model 1537/1697 手柄上的许多设计缺陷,更加可靠。该手柄已被改进版 Model 1914 手柄所取代。
163 个问题 查看全部
What is easier to replace? The expansion port or the motherboard?
The expansion port on my controller stopped working, haven't opened it up but It is definitely the expansion port (the 3.5mm adapter works just fine in other controllers) I was wondering if the best option for fixing it would be replacing the single port or the whole motherboard.(I have no idea which one its connected to)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
I’d open it up and see if you can’t spot the problem, look for burned components:
Xbox One Wireless Controller Model 1708 Bottom Motherboard Replacement
这个答案有帮助吗?
得分 2
添加一条评论
The issue with replacing the port is it’s mounted with SMD soldering so you can’t easily replace it. Unless you have a donor secondary board and really good soldering skills, you will mess up the connector if you even try removing it.
That said, it’s rare for the connector to fail in general (unless you spilled Mountain Dew on the port). Try doing what @mayer suggested and look for burned resistors and capacitors. Unlike the connector, it’s practical to replace SMD parts on that level. It also wouldn’t hurt to protect the connector with kapton tape to err on the side of caution.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Chris 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 4
总计 346
