跳转到主内容
Repair and disassembly guides and support for dish washing appliances.
707 个问题 查看全部
Whirlpool Dishwasher starts after keeping the door pressed manually.
Hi, I have an Ikea whirlpool dishwasher. It had a free fall door because hinge string was broken which I replaced. Now, it starts when I keep the door pressed manually. It runs for sometime even if I stop pressing the door but stops after sometime. If I presss the door again then it starts again but stops after sometime if I stop pressing the door. I already open the door and checked all the wires and everything is connected. I also cleaned the area for clogging and anything stopping the close the door properly. Could it be door latch or something else need to be replaced?
Thanks
Vikas
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
3条评论
I need your model number to be able to locate parts.
完成的
Hi Mayer, Thanks for your reply. It's integrated whirlpool from Ikea. I can't see actual model details. It has service no. as 854586701001 and serial no. as 990740072630.
完成的
See if you still have the operators manual, iy will have the model number. I can't find the correct parts without it.
完成的
添加一条评论
1个答案
最有帮助的答案
it sounds like the latch is not working like it should , when you close it the latch on the shell not the door is not pushing in the switch to turn it on , check it out ans it should have an adjustment , screws or a screw to adjust let me know
这个答案有帮助吗?
得分 1
3条评论:
I can't see any screw for the adjustment of the latch.
完成的
Thanks gadget1961, you were spot on. There was some misalignment between latch and the door tilt lock. I happened perhaps when the door spring-thread was broken (which I had replaced earlier). I opened everything and checked carefully and set it back and everything is working as normal :) . Thanks a ton to give new hope !!
完成的
Good glad I could help . I am a maintenance super 34 years for an apt community. We fix all our appliance's and then some
完成的
添加一条评论
添加你的答案
Vikas 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 7
总计 885
