Whirlpool Dishwasher starts after keeping the door pressed manually.
Hi, I have an Ikea whirlpool dishwasher. It had a free fall door because hinge string was broken which I replaced. Now, it starts when I keep the door pressed manually. It runs for sometime even if I stop pressing the door but stops after sometime. If I presss the door again then it starts again but stops after sometime if I stop pressing the door. I already open the door and checked all the wires and everything is connected. I also cleaned the area for clogging and anything stopping the close the door properly. Could it be door latch or something else need to be replaced?
Thanks
Vikas
3条评论
I need your model number to be able to locate parts.
由 mayer 完成的
Hi Mayer, Thanks for your reply. It's integrated whirlpool from Ikea. I can't see actual model details. It has service no. as 854586701001 and serial no. as 990740072630.
由 Vikas 完成的
See if you still have the operators manual, iy will have the model number. I can't find the correct parts without it.
由 mayer 完成的
