跳转到主内容
加入维修社区 - 创建账户
型号 A1369,1.6、1.7 或 1.8 GHz 处理器,64、128 或 256GB 闪存存储
Retrieve data from SDD on MacBook Air 2011
Is there a way to retrieve data from an old Samsung SDD taken from my Mac Air 2011? The Mac was totally dead after water damage but I want the photos. I have now taken the SDD out and thought perhaps there is a caddy I could buy, etc.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
1个答案
已选择的解决方案
You need an OWC Envoy enclosure
https://eshop.macsales.com/item/OWC/MAU3...
https://www.adorama.com/owcmau3evy11.htm...
这个答案有帮助吗?
得分 6
10条评论:
Thanks Mayer. Just ordered!
完成的
Hey Alan - did it work? I'm wondering if I can get data off of a 'dead' SSD...
完成的
@kdnavrat - I'm sure it worked! I've salvaged a few wet systems data using the OWC Envoy cases. The only issue is how wet your SSD got as salt water will do a number of the traces.
完成的
Oh sweet! I'll try it. I just ordered an OWC Envoy enclosure and I assume I just put the 'damaged' SSD in it and see what I can find? Thanks
完成的
I can't get the Mac to "see" the SSD in the OWC Envoy - it acts like it just can not be found. Any suggestions?
完成的
显示更多的5条评论
添加一条评论
添加你的答案
alan s. 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 26
总计 748
