Metallic connectors inside key fob not attached to silicone button pad
My metallic connectors inside key fob not attached to silicone button pad & have become detached - so the whole fob is no longer working. What is the best adhesive to try and re-attach the metal connectors to inhibit them from wondering around causing a mess?
4条评论
Can yo post some pics so we can see what you are facing here 在已经存在的问题里加入图片
由 Dan 完成的
You appear to be missing some of the pads! Correction: I count five here two is still in the key and three on the table. You need seven!
由 Dan 完成的
The key fob only shows 5 buttons on the front. There are 3 on the table and 2 of them still in the key fob. They look pretty dirty and need cleaned to make a good connection with the board.
由 Joshua Freeman 完成的
All these comments are good, but I had the same problem with my key fob. When the discs become dislodged that particular button will not work. Mr personally,I used Super glue, just a touch...
由 Ray Sanders 完成的
