跳转到主内容
Water damaged MacBook Air, can I chisel down the potential problem?
Last year I had spilled soda on my MacBook Air 13” early 2014. I would eventually have problems with booting, but when it’s on I have an issue with the trackpad and keyboard which I wrote a topic on on this forum. I had issues with turning on the MacBook so I didn’t continue.
Today I tried turning it on after a long period of time so I know the power discharged. I held the power button and it booted up! I still had the same issue with the trackpad. I shutdown the MacBook and now I’m unable to power it back on. I’m not sure if I’ve waited long enough for a complete discharge but when I plug in the MagSafe it turns orange indicating charge. When I try hitting the power button it turns green indicating the power button is registering a press. But when I hit the power button it does not turn on.
I’m hoping with this information I can help diagnose the situation further. It looks like it can theoretically power on under the right condition. Perhaps with a power discharge?
I imagine the issue could be corrosion but could it be the battery or another part I could replace from what I’m describing?
Update (05/28/2019)
I did not do anything. I eventually just stopped powering it on. I don’t have any tools to crack open the MacBook yet. I initially just cleaned the surface so it looks normal.
I was hoping I could target a few areas like just the battery and trackpad. I imagine leaving it like that did not help the situation.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
4条评论
完成的
The first question is did you follow the guidance? Did you clean the corrosion up and replace the trackpad and if needed the trackpad cable?
完成的
No I did not. I did not clean it.
完成的
Then your procrastination may have made this worse! Hopefully its not too late! Take the logic board out as outlined here MacBook Air 13" Early 2014 Logic Board Replacement As well as inspect the rest of the system for damage.
完成的
添加一条评论
1个答案
已选择的解决方案
davidrak
you have not told us what you did about the initial soda spill. My suspicion is that the logic board most likely was not properly decontaminated and is experiencing failure by corrosion. At minimum you want to go ahead and remove the board etc. MacBook Air 13" Early 2014
Post some pictures with your question of what your board looks like so we can see what you see. 在已经存在的问题里加入图片 Right now you do not want to try to start your computer since that could make a bad situation worse.
这个答案有帮助吗?
得分 2
1条评论:
Thank you to everyone for all your help! I fixed the problem!
Having a year of drying seemed to be ok with the laptop. There was no water damage inside but it may have effected the cables. All I did was disconnect the power cable, the trackpad, and the keyboard, clean the connectors, and reseat the cables. It looked like any potential water might’ve baaaaarely got on the cable, but just doing a quick wipe and reseat fixed the problem. No need to replace anything major. Woohoo!
Thanks for all your help guys! Good luck to anyone who has the same problem.
完成的
添加一条评论
添加你的答案
davidrak 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 110
