Actifry tefal error 6
I get error 6 after few minutes.
Update (01/10/21)
The problem was on the electric circuit .
I have replaced the capacitors and the problem has been resolved!!!!
There are two capacitors. Change both of them.
这个答案有帮助吗?
Can u put pictures please
There are a couple pictures here :
Where are they..? And what are they?
@Adrian Martin Take a look at the link in the second comment here by Eric B; there's a video and picture and places to buy the parts. It's in French, but that's what Google Translate is for.
I have got the same error. But the Black Actifry (model serie:025) does not have any capacitors, I discover... But I did get a third capacitor from the supplier, for free ;-)
I have replaced both the motor and thermostat and that did not help. I did not have the tool to check circut board but visually all looked fine. At least now after 10 times of disaassembky I know how to do it. I will check the capacitors again.
The official info about contacting electric supply company is absolutely out of the question. I have tried different networks and sockets.
这个答案有帮助吗?
So how it went? @rogerino
@Carlos Garcia quick question. do you have the error 6 on the actifry? Error 6 appears to be related to overheating of the 330nF capacitors on the circuit board. If you have this error post a couple of pictures of your circuit board so we can check things out.
Do you mean rhe gray capacitors
I have model IH7000 and it gave the same error... now it is OK
I am happy that I found a way to change the 334k capacitor & 100uf/35 capacitor error e6
过去 24 小时: 4
过去 7 天: 8
过去 30 天: 96
总计 29,608
7条评论
how to repair E5,E6 on fryer tefal
由 baodo1973 完成的
Check the HZ may be defrance then specific of machine 50 or 60
由 Medhat Ali 完成的
My actifryer squashes all the food up what would the problem be
由 Anne lennon 完成的
Please can you advise how to change the capacitors as ours started throwing the err6 fault code today but after 6 or 7 times of it doing it every minute or so it stopped and worked fine again so i imagine its on its last legs or overheating maybe
由 Martyn Couper 40 完成的
Could you advise where you got the capacitors and how much they cost please
Thanks regards Martyn
显示更多的2条评论
