跳转到主内容
Repair and disassembly guides and support for dish washing appliances.
707 个问题 查看全部
Whirlpool Dishwasher Stops after Filling, only clicking heard
I have a whirlpool gold series dishwasher. It will fill with water for about a minute and then just start clicking. I’ve tried holding the door shut to see if it is the latch connection. When we did let it cycle, it still opened the soap and drained at the end.
I had a repair guy out and he did check it, he put it through a self diagnostic and there were no error codes. He said it was the control board. Before I start throwing parts at it, I wanted a second opinion.
The machine is just shy of 5 years old.
Thanks in advance for any advice I can get.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Cause 1
Water Inlet Valve
The water inlet valve opens to allow water to enter the dishwasher. If the water valve is clogged or defective, water will not flow into the dishwasher. Water inlet valves are not repairable—if the valve is defective, you must replace it.
Cause 2
Water Supply Problem
Over time, calcium deposits can build up in the water supply valve or in the small filter screen inside the water inlet valve. If the water inlet valve is clogged with sediments, the dishwasher won’t fill properly. Before working on the water line, first shut off the water supply. Inspect the valve to determine if is clogged. In addition, check the water pressure to the valve. The water inlet valve requires at least 20 psi to function properly.
这个答案有帮助吗?
得分 1
添加一条评论
Tying threads together for this issue, I have a potential solution here: Whirlpool Dishwasher stops after filling with water
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jennifer 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 32
过去 30 天: 150
总计 4,326
