跳转到主内容
Released September 15, 2008 10.1 megapixels, 5x optical zoom, 3.5-inch LCD, HD Movie Recording
Camera Memory stick locked
Memory stick is locked. not able to shoot photo, nor i can delete photos.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Is there a lock switch on the stick?
完成的
添加一条评论
1个答案
If you’re using the older style of memory card called the Memory Stick Pro, you should have a lock switch on the back of the card that might’ve accidentally gotten switched on. They look something like this (a red part of the switch will show if the lock function is turned on):
However, if you’re using the newer Memory Stick Duo or Memory Stick PRO Duo card, it doesn’t have a lock switch, and that might mean that there’s something electrically wrong with the card or camera. If you have another memory stick you can try in the camera, you can check and see if the error still shows up.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Umesh Kawalkar 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 682
