跳转到主内容
Power on but no singnal to monitor or keyboard
Hi!
I bought a new motherboard, cpu and ram to my PC. When I connected everything to the computer I turned it on but i had no singnal to my monitor or keyboard.
Spec: CPU: I5-9600K RAM: HyperX Fury DDR4 3200MHz 16GB Motherboard: MSI Z370I Gamin Pro Carbon AC GPU: EVGA 970
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Have you made sure the display cable from monitor is plugged into the back of the graphics card and not behind the motherboard?
Also try reseating all the power cables to the motherboard and graphics card.
这个答案有帮助吗?
得分 1
5条评论:
I have tried both and all cables heve been checked and reconnected. No luck.
完成的
Hi @rianthelion ,
Have you got a speaker connected to the motherboard?
If not connect a speaker to the motherboard's speaker header pins and check if there are any beeps on startup
JFP2 connector :
pin 1 Speaker -ve
pin 2 Buzzer +ve
pin 3 Buzzer -ve
pin 4 Speaker +ve
What type of keyboard is connected PS/2 or USB?
完成的
No beeps, The USB ports on the motherboard is dead no sign of power. I tried different this keyboards phone charger etc.
完成的
Hi @rianthelion ,
Try disconnecting/removing all except PSU, RAM, keyboard and monitor from the motherboard, i.e. barebones PC - no HDD, no ODD no GPU card etc and check if you get display and can get into BIOS OK.
完成的
Found the problem! The motherboard don't have support for 9th gen Intel prossesor you need to update bios first. Buying a cheap celeron so I can uptate bios. Thanks for your help!
完成的
添加一条评论
添加你的答案
RianTheLion 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 864
