跳转到主内容
Announced on October 16, 2014, the iPad Air 2 is a thinner successor to the iPad Air.
Home Button problem after screen Repair
Hello I have replaced alot of screens on iPads but this is the first time I have seen this,
When I replace the screen assembly on the iPad Air 2 I can not get the home button to work at all, the OEM or a new one. I have tried 2 different screens with no luck, now if I put either button back on the cracked screen the home button works, what could be stopping the home button from working after doing the screen replacement
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
On step 36 of this guide there is a little black sticker over the home button connection with the screen assembly. Did you reattach this sticky tape after assembling the replacement screen.
There could also be a question over the reliability of 3rd part screen assemblies, you have proven that the home button works when using the original screen so as long as you have transferred all of the components from the original screen across to the replacement screen then the issue is with the replacement screens.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Adam Longtin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 90
