跳转到主内容
加入维修社区 - 创建账户
Whirlpool 品牌烘干机的维修指南和技术支持。
Igniter does not come on
Hi folks, I have a Cabrio Accudry WGD5600XW0. There was no heat, so over span of time troubleshooting I have replaced the thermal fuse, igniter, high limit thermostat, and thermal cut off. I have made sure there is gas and that the airflow is good. The board does not give off any errors in diagnostic mode. The igniter does not come on and I have tested all the components with a multi meter and all test fine. I am at a loss.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
When the thermostats, fuses, ignitor and flame sensor function correctly, they send a signal to the coils or solenoids attached to the top of the gas valve. These coils or solenoids open the valve and release the gas into the burner assembly. If the ignitor glows and does not ignite a flame after 90 seconds, one or more of the gas valve coils or solenoids have failed. If the ignitor still fails to ignite the flame after you replace the coils or solenoids, the gas valve may have failed, and you will need to call an appliance service technician to replace it.
这个答案有帮助吗?
得分 2
4条评论:
Igniter does not come on at all. Is that cause by the solenoids?
完成的
Sounds like it to me.
完成的
@freedo my dryer is not working right I have replaced the igniter the flame sensor and the 2 coils and still not working
完成的
@joserdelga87491
What is the model number of your dryer?
完成的
添加一条评论
添加你的答案
Freedolay 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 18
总计 944
