跳转到主内容
The Canon AE-1 is a 35 mm single-lens reflex (SLR) film camera for use with interchangeable lenses.
How do I replace the film door?
my film door latch got messed up and doesn’t close properly and long story short i need to replace it. i bought a replacement door on ebay, how should i go about replacing the film door?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Post a few pics of the damage so we are working on the correct side. 在已经存在的问题里加入图片
Are you able to lift the knob up and can see the latch within the body raise up?
完成的
yes i am able to lift the knob up but im not sure which latch you're referring to
完成的
添加一条评论
1个答案
最有帮助的答案
@gracej
open the film door all the way. Remove the door by pulling the release pin in a downward direction.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
grace j 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 13
总计 1,224
