跳转到主内容
发售于2017年11月3日。型号为 A1865, A1901。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供银色和深空灰色。(读音与“iPhone 10”相同)
1199 个问题 查看全部
How does flood illumator look on ear speaker for iPhone X
The ear speaker flex on my iPhone X is torn and cannot be repaired. Which part of the flex is the flood illuminator and which parts do I need to transfer to keep Face ID. Pictures/videos will be much appreciated.
thank you
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
You can see the flood illuminator in the second image here:
iPhone X 听筒+前传感器组件的替换
If you are asking which traces in the flex cable is responsible for the flood illuminator, I can’t help you with that.
As far as I understand, unfortunately the entire front sensor assembly is paired with the iPhone and must be transferred over to retain FaceID
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Hamza Majid 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 5
总计 194
