跳转到主内容
加入维修社区 - 创建账户
USB 闪存盘(也称为闪存盘、U 盘或移动存储棒)的维修指南和技术支持。
Why is my USB device not recognized?
The system of my computer is Windows 10. When I plugged in my USB hard drive it just doesn’t turn out and shows that "USB device not recognized". I have upgraded all the drivers. They are up to date but still not working. What can I do with it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
3个答案
已选择的解决方案
Hi, can you check the USB device from the Disk Management?
Way to check with these steps:
  1. Press Win Logo key + R and then type: Diskmgmt.msc
  2. Find your USB device there.
Give me the feedback, thanks.
这个答案有帮助吗?
得分 2
3条评论:
I have followed the suggestion and the device can be found already. Thanks a lot!
由完成的
Hi, if you can find the USB device there in Disk Management, that means the device is still working but corrupted due to some technical reasons. To fix this error, you can try to retrieve the data first from the USB device and then follow the steps with this link to fix: https://www.r-datarecovery.com/usb-devic..., leave me the feedback here, thanks.
由完成的
I've fixed the problem with your suggestion. The software is so convenient to use. Thanks a lot!
由完成的
添加一条评论
Try shutting down Windows from the Start Menu.
When shut down unplug the computer for about 5 minutes.
Plug back in and turn on.
Now try plugging in the USB device and see if it is recognised.
Let me know if it works.
这个答案有帮助吗?
得分 1
1条评论:
Thank u for your advice but the problem still remains :(
由完成的
添加一条评论
Hi @jityvub
Had you tried on another computer and another USB port?
You mentioned it is a USB hard drive. Do you have model no of it?
When you connect the drive to your computer, I presume it is a mechanical HDD, do you hear any weird sounds coming out from the hard drive? e.g. some tick tick or motor spin and stop abruptly?
这个答案有帮助吗?
得分 1
2条评论:
It is just a common USB flash disk.I've changed the other USB port and I can find the weird sounds but the error remains. I only have one computer can be used at this stage.
由完成的
no matter what... if data is important, if it can still be access, copy it out.
由完成的
添加一条评论
添加你的答案
lozemyti 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 27
总计 2,579
