跳转到主内容
加入维修社区 - 创建账户
Jeep Cherokee (XJ) 是一款由 Jeep 在 1997 年至 2001 年间制造并销售的紧凑型 SUV。它沿用了原始全尺寸 SJ 车型的名称,但没有采用传统的非承载式底盘(body-on-frame chassis),XJ 转而采用了轻量化的一体成型机身设计。
Is a vehicle still drivable with a bypassed heater core?
I have a 1999 Jeep Cherokee Sport 4WD 6 Cylinder and lately I've been having alot of issues with it overheating on me. I can only drive it about 2 miles from my house before it overheats and coolant starts flowing out. About a month and a half ago my dad and I replaced the Clutch Fan, Thermostat, Serpentine Belt, & Water Pump now the Heater Core is out on it so my dad is going to bypass the Heater Core and I know that I will no longer have heat but that's not an issue at the moment. However I'm questioning if I'm going to be able to drive the Jeep with a bypassed Heater Core because I dont quite know what all happens when you bypass a Heater Core. If anyone could shed some light on this I would greatly appreciate it.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
5个答案
最有帮助的答案
@stephanie_1314
yes it is. Been driving my CJ like that for about 2 years. Eventually you do want to change the heater core or fix it (I myself will do the same thing;-). All that is being bypassed is the hot water flow through the heater core
You and your dad may find this document helpful Jeep Cherokee Heating and Cooling
这个答案有帮助吗?
得分 4
添加一条评论
Depends on the state if you can and how long it works.
You can get away with it in a warm climate like as a long term solution (or a permanent bypass on high mileage beaters) in a state like Florida since cold weather is rare and only lasts 1-2 days at most, but in a consistently cold state bypassing it can be less then ideal. It is an average $800-1,000 repair, so bear that in mind.
On an older high mileage vehicle like a 200k mile Toyota I'd just bypass the thing and call it good, but if it was reasonably new I may have repaired it. Over here, we just bypass them on old vehicles that aren’t worth much due to mileage (but work fine because Japanese quality), or worth more in parts. We're not going to spend $1k on a thing you almost never need when the 200k mile Camry already works otherwise.
这个答案有帮助吗?
得分 2
添加一条评论
Yes u can drive it won t hurt a thing.
这个答案有帮助吗?
得分 0
添加一条评论
Yes you can, however you won’t have a defroster anymore so if your windshield ices/fogs up then you will have no heat to clear it.
这个答案有帮助吗?
得分 0
添加一条评论
Seems like this isn't really related to the heater core. Back when I bypassed the heater core on my old Cherokee, the AC blew freezing air but the Jeep still ran fine. The real issue here is why your rig's overheating like crazy. Your problem sounds more like the cooling system isn't circulating properly. Check if the water pump's actually working—after starting the engine, feel the temperature difference between the top and bottom hoses of the radiator. If you've got an infrared thermometer, scan the hoses for temperature changes. Don't force it to run like this.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Stephanie C 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 24
总计 2,157
