跳转到主内容
加入维修社区 - 创建账户
Samsung Galaxy S9 的型号为:SM-G960XU。它是三星 Galaxy 系列的第九代机型,于 2018 年 3 月发布。有丁香紫、午夜黑和珊瑚蓝三种颜色可选。
My touch screen is unresponsive
While on facebook my touch screen just stopped working… The screen comes on and stuff like normal… But it just isnt responsive at all..
I tried almost everything.. Tried reseting it i tried booting it into safe mode…
But still nothing
Any other tips before i perform a factory reset.. Which i really do not want to do
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
3条评论
Do you have any screen protectors installed? If so, remove them to see if anything changes.
完成的
Have you ever had it opened before?
Highly doubt its software
is the phone damaged physically?
完成的
The phone was never opened before
完成的
添加一条评论
4个答案
最有帮助的答案
When the screen touches itself its called ghost touch. This happened when there is physical damage to the screen which calls for a replacement.
这个答案有帮助吗?
得分 1
4条评论:
I was hoping this isnt the :'( the phone is still new it never fell or went in the water im not sure if samsung will replace it either
完成的
So go and ask samsung that's a good idea.
完成的
Can it be a software issue like maybe cause I havent formatted the phone as yet and im praying thats the solution...because I mean the phone never fell when I had it with me and it has never been open it was in a cover and had a tempered glass from the time I got it
完成的
Highly don't think so but I should not stop you from trying.
完成的
添加一条评论
Try connect with USB-C/OTG reduction some mouse.... Try backup your data first on memory card... After hard reset can help.... Maybe.... But data you can
这个答案有帮助吗?
得分 0
2条评论:
I am actually using a mouse will backup and reset pray its not any hardware
完成的
the screen also started to touch itself recently
完成的
添加一条评论
If it is new and if it's not cracked or water damaged then Samsung should be able to sort that out for u, just backup stuff u need first though
P.s did u remove the tempered glass u said u had on it and try it without that on???
这个答案有帮助吗?
得分 0
添加一条评论
Unfortunately it’s likely not a software issue. If you said the screen is touching itself (Ghosting) then that likely means it’s a hardware issue with the screen itself. You may have just gotten a bad screen. If the phone is still under warranty then I would suggest you back up what data you need and claim the warranty on the device.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Brentley Kyle Tikum 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 23
总计 3,117
