跳转到主内容
加入维修社区 - 创建账户
Repair guides and support for a wide range of radios.
Vintage component Identification help needed.
Hi all, I attached a picture of a component that I am having trouble identifying. The text reads 38132 OR 38|32 RCA CNK IC, also I am on the hunt for Sherwood S-8500 schematics!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
8条评论
looking at the other side how many connections does it have, two or three?
完成的
it has three pins
完成的
So you have a transistor which could be a geranium or silicon configured as either a NPN or PNP.
完成的
Right, I am hoping to find specs as I need to find a replacement.
完成的
Here's one possible source for the Schematics SHERWOOD SCHEMATIC: MODEL S-8500 FM STEREO RECEIVER
Thats the best I can do. Sorry
完成的
显示更多的3条评论
添加一条评论
1个答案
已选择的解决方案
That is reference designator Q308 which is a RCA NPN transistor. For your S-8500 transistor Q208 and Q308 are identical. The original transistor was either a RCA 38132 or a Fairchild 40361F
Type Designator: 40361
Material of Transistor: Si
Polarity: NPN
Maximum Collector Power Dissipation (Pc): 1 W
Maximum Collector-Base Voltage |Vcb|: 70 V
Maximum Emitter-Base Voltage |Veb|: 4 V
Maximum Collector Current |Ic max|: 0.7 A
Max. Operating Junction Temperature (Tj): 200 °C
Transition Frequency (ft): 50 MHz
Forward Current Transfer Ratio (hFE), MIN: 75
Noise Figure, dB: -
Package: TO5
These documents should be of interest to you SchematicSherwood-S-8500-Partslist.pdf
这个答案有帮助吗?
得分 7
4条评论:
YeSss!! thank you so much OldTurkey! If you are in located in the states and their is a concert you want to attend (within reason) let me know and I'll try to hook you up with a pair of tickets. I am a promoter/talent buyer for a performing arts center in MA and can sometimes get tickets for shows in the US. I owe you one!
完成的
Aaron, OldTurkey lives in TX, checkout his info card for email.
Check out this vid If You Have a Repair Question These Guys Have The Answer!
完成的
Aaron that is awesome! Great that I could be of assistance ;-)
完成的
why can't we upvote comments yet?? great job OT03
完成的
添加一条评论
添加你的答案
Aaron 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 15
总计 257
