跳转到主内容
The Kenmore Elite HE3 is a washing machine by Kenmore.
669 个问题 查看全部
Kenmore elite Oasis HT leaking
(I know, kind of an older model). It leaks underneath during cycle. It’s obviously happening during spin and I can see the actual holes where it is coming out but I don’t know what is causing it. Can anyone help?
The last one is from underneath and I can see the water is coming from the tiny holes at the middle of the “wagon wheel spokes”.
Update (03/24/2019)
Model # :11028092700
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
6条评论
Here’s pic if all info from a service receipt [image|1717260]
完成的
[image|1717260][image|1717264]
完成的
Great, thanks. Now lets see what we can find out specifically to your washer
完成的
Okay ty. So i have been researching and it sounds like I need the part number W10435302kit to replace bearings and drum seal. We really hadn’t questioned the noise level during spin, since our washer is pretty old but the noise and the holding water in the outer tub sounds like what others described. What do you think?
完成的
.... my problem also though, is I’ve got it all taken apart down to the drum and I can’t get it out… It won’t budge. Do you think rust? We have pretty hard well water and there’s a lot of lime buildup everywhere too
完成的
显示更多的1条评论
添加一条评论
1个答案
最有帮助的答案
@gainey that looks like a leaking tub seal. The main tub seal is located between the transmission and the outer tub. there is always the possibility of a bad hose or a split tub. you will have to further disassemble your washer to make a definite diagnosis. Let us know your washer exact model number so we can possibly help you out further.
这个答案有帮助吗?
得分 1
6条评论:
Okay ty. Any idea where the model #is?
完成的
Ive gotten the water drained from outer tub now
完成的
Okay model # is 110.2808, 2809
完成的
Anyone there?
完成的
Kenmore Washing Machine 110.28092700
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Toni 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 277
