跳转到主内容
第四代 iPhone CDMA 版的维修指南。型号 A1349,有8,16,以及32 GB 存储空间的选项。
not enough instruction for me
I have a new iphone 4g from verizon. of course we broke the front on the second day. I did some research, and it did not appear that hard to change out the glass. I order a kit, the kit came, but apperantly apple changed the screws to a kind of star screw. Reseached that problem and got the right tool. Today I dove into the job, found the instructions not to be exact, but got it apart. Now I find the the front replacement glass is not right. It does not have the, (i think it is called a digitizer) plate with it and the screws placement tabs are not right. So now it is back to the drawing board. I have another glass, but when I tried to seperate the glass from the digitizer, the digitizer fell apart.
Can I get the right front with the digitizer with it???
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
It sounds to me like you got either the wrong part or the individual parts. Watch out for "interesting vendors" that swear it can be done in separate pieces. Here is what ifixit has to say "It is a complete part with the LCD and the glass fused together. It includes the speaker grill and front facing camera lens installed.
The glass and the LCD cannot be replaced individually as they are inseparable. Don't believe the other companies that try to sell you them separately." Do a search for the iPhone 4 screen on here and you will see that most attempts to install or to separate it have failed. ifixit has the assembly here and I am certain it is also available on other places. Depending on your location, a good Google search will help you with that. Good Luck.
Replace a cracked glass screen or malfunctioning display in a CDMA model iPhone 4.图片
产品
iPhone 4 (CDMA/Verizon) Screen
$34.99
这个答案有帮助吗?
得分 2
2条评论:
Thank You, That sounds right, now I know.
完成的
You are welcome and good luck.
完成的
添加一条评论
添加你的答案
hendrixwilliam 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 900
