跳转到主内容
Shark Navigator Lift-Away (NV352) is a type of vacuum that functions on both hardwood and carpet with a lift-away feature. The NV352 includes several cleaning attachments. The vacuum was released in 2008 and is often referred to as the Shark Navigator Lift-Away.
Why has the roller brush stopped going around?
Why is the roller brush not going around. Could the belt slip off?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
If your Shark vacuum stops moving suddenly during use, see the Shark ION Robot R75 Stops Moving Unexpectedly problem page for possible problems and solutions.
Use this guide to help diagnose the issue:
Shark NV352 Roller Brush Replacement
这个答案有帮助吗?
得分 3
添加一条评论
Because the handle needs to be pulled back and the switch needs to be turned on to BRUSH ROLLER ON.
这个答案有帮助吗?
得分 1
添加一条评论
broken belt
follow this video
https://www.youtube.com/watch?v=zkDeWuXb...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Pamela McCarty 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 308
