跳转到主内容
加入维修社区 - 创建账户
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
Unable to activate iPhone 7
Restored iPhone 7 to iOS 12.1.4, the phone was stuck on the Apple logo and this is why I had to restore it. It restored successfully and got me to the Hello screen but iTunes says “The iPhone could not be activated because the activation information could not be obtained from the device”. On the iPhone itself it says “Unable to activate” “An update is required to activate your iPhone”. How do I fix this, what could be the problem?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 16
添加一条评论
2个答案
已选择的解决方案
Check the iPhone via 3UTools and see if IMEI is present. You can also check this on the activation lock screen with the little circle information symbol at the bottom right of the screen.
It sounds like a baseband fault which means it’ll require micro-soldering to fix from a reputable phone repair shop.
这个答案有帮助吗?
得分 5
5条评论:
I do micro soldering. The IMEI isn't present in 3U tools. Only the serial number. And on the phone in the "i". There is no other information but the serial number only
由完成的
Sounds like baseband PMU needs to be replaced as you've said it was stuck on apple logo and now this issue occurs.
由完成的
What about the Baseband CPU next to the CPU?
由完成的
Could be that too but you need to be careful removing it as it's near CPU that can only be reballed and not replaced as it's uniquely programmed to the phone for cellular service.
由完成的
Any updates? I've seen two of these in the past 24 hours.
由完成的
添加一条评论
iPhone 7 series phones have serious issues.There is two component stands for that problem.
1- BBPMU
2-BBCPU
If the BBPMU is damage that the solution but if the BBCPU is shorted no any solution.
这个答案有帮助吗?
得分 2
1条评论:
No result
Same problem
由完成的
添加一条评论
添加你的答案
Dennis Warren 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 32
总计 14,862
