跳转到主内容
加入维修社区 - 创建账户
{A1706 / EMC 3071}—2017 年 6 月发布,这款 13 英寸 MacBook Pro 搭载了主频最高可达 3.5 GHz 的 Kaby Lake 架构 Core i7 处理器,Turbo Boost 最高可达 4.0 GHz。
How to fix broken/loose key cap
I broke my J key cap when cleaning. The little clip on the back of the key fell ok and now the key is loose. Anything I can do (ie ordering a new key cap) or will I have to take the laptop in?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
添加一条评论
6个答案
已选择的解决方案
I think it came loose while you were just typing on it.
If so, it is covered by Apple by this Service program:
https://www.apple.com/support/keyboard-s...
If you really are sure you did knock it off, then it will probably require an upper case replacement as these new keyboard are almost impossible to work on.
Here’s the part you will need:
MacBook Pro 13" Retina (Touch Bar, Late 2016-2017) Upper Case
Replace an upper case, keyboard, or touch bar compatible with the Late 2016 to Mid 2017 model 13" MacBook Pro Retina Touch Bar laptop.图片
产品
$98.99
这个答案有帮助吗?
得分 5
添加一条评论
https://howtofixgadgets.com/macbook-key-...
This will help you. In my case i broken my space key i was unable to fix it. Then after some research i found this article first i visited service centre to buy a new key but in my local they say they don’t have because my mac is too old. Then i visited local repainting shop and ask for a key what the shopkeeper did is he remove a key from a old not working laptop and replace it to my laptop.
While replacing the key please watch 10 - 15 video online it will help you. Replacing keys of butterfly keyboard is really complex.
All thanks this article just because of it i saved my money else i have to buy a new keyboard.
这个答案有帮助吗?
得分 2
添加一条评论
you may be able to push down on the key until it “clicks” on regular keyboard but because the new MacBook pros her those low keyboards with a different mechanism it might be different. you can go to https://support.apple.com/mac to see if people have the same problem.
这个答案有帮助吗?
得分 1
1条评论:
and what Mayer said
由完成的
添加一条评论
You can buy replacement key caps and perhaps the butterfly levers underneath if you can take them off. But if there is anything damaged on the keyboard frame or support, that is going to be an expensive repair.
这个答案有帮助吗?
得分 1
1条评论:
The new butterfly keys are very fragile! The little tabs snap off taking them off and often times they get distorted trying to put them back on.
I've given up trying Ben, let Apple eat it.
由完成的
添加一条评论
thank you for helping me
这个答案有帮助吗?
得分 0
添加一条评论
Try this answer:
Try to squeeze the tiny clips together at the top of the key between your fingernails (or gently with some needle nose pliers maybe). The goal is to make them slightly tighter. They must slightly distort with use. It doesn’t take much, so don’t overdo it!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Cody Dutcher 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 38
总计 54,306
