跳转到主内容
加入维修社区 - 创建账户
Asus Q551L 是 Asus 于 2014 年发布的一款二合一设备。该设备配备 15.6 英寸屏幕,搭载 2 GHz Intel Core i7 处理器。
Is This A Battery Connection Issue?
I recently just upgraded to an SSD and I followed a video that told me to unplug the battery as the first thing to do when starting. I did all of that and got the SSD in, however whenever I went back into the computer it was saying “No battery is detected” I thought maybe I just didn’t put it back on properly so I went back and wiggled it a alittle bit but still the same thing when I opened the computer. I took it off one more time and realized that there were small bits that look like they came off with the battery connector when I took it off the board. Would this cause my computer to not recognize my battery? For whatever reason it works fine while it’s plugged in but it will start to die (but not immediately) if I take it off. I would really appreciate anybodies help in trying to diagnose what I could do about this issue as I am not too tech savy lol. Thanks guys.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Two pads are ripped off the battery connector and the battery connector needs to be resoldered.
For the two ripped pads jumper wires will need to be put in place to fix connection but where the jumper wire should go to is unknown as it'll need to be checked via board view and schematics found on the internet if possible.
You would need to take the laptop to someone that does board repairs on laptops to fix this.
这个答案有帮助吗?
得分 2
1条评论:
Thank you so much! One more question for you: How much would something like that cost me? (I know prices may vary but if you could give a guesstimate)
由完成的 分享
添加一条评论
Scrape off some PCB mask where the traces are and get a CircuitWriter trace pen, which looks something like this. I would buy it anywhere but Radioshack for obvious reasons, but it’s going to be the same thing no matter where you buy it.
It isn’t quite as percise as a schematic and proper board repair, but it will get you out of trouble if you aren’t able to find a schematic and do the repair that way.
这个答案有帮助吗?
得分 2
1条评论:
Is there a video that could help me do this myself? Or should I have someone else do it for me?
由完成的 分享
添加一条评论
添加你的答案
Justin Moyle 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 9
总计 441
