跳转到主内容
加入维修社区 - 创建账户
Samsung Galaxy Grand Neo 于 2014 年 2 月发布。这是一款 5.01 英寸显示屏的中端智能手机,且有一个双 SIM 卡版本。GT-I9060I 型号被称为 Samsung Galaxy Grand Neo Plus。
How to fix the power button?
my power button doesn’t work
you have to press it hard to get it work, at some point i guess i pressed it too hard it stopped working
so how could i fix it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Lucky for you this is an easy job
you just need to buy Grand Neo Plus power flex use that search term on ebay
the phone uses just PH00 screws, very easy to open, the flex just unclips
also, thse flex cables can be cleaned, use tweezers you can peel off the dome key and then use a pin to lightly scuff up the contacts, scuff up the underside of the dome too.
you may have crushed the dome so order the part and clean the contacts to get you through
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
خالد 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 18
总计 783
