What is the part that should be replaced if the display is flickering?
My Ipad mini model is A1432.
After I had left it idle for 1 year and got it back to use a month ago, the display has been flickering like ghost touching as the video posted underneath shows.
If the brightness level is low, the flickering becomes more serious. The lower, the more serious, vice versa.
Flickering when brightness level is low:
https://www.youtube.com/watch?v=KZlUyVAc...
Flickering when brightness level is high:
https://www.youtube.com/watch?v=ytaX8ANv...
In this case, if I want to repair it by myself, what is the component that I should replace?
Is it the LCD screen? It is good if anyone could provide a pic of that particular part.
Would I get to know better which part that I should replace after the Ipad is opened? Is there any detailed guide that I can follow for checking?
3条评论
Thanks for the reply and the guide.
Suppose I want to replace the LCD screen, how do I stick back the front panel after the adhesive glue is undermined?
Is it possible to just plug it back and use the tablet as usual without applying any extra glue?
由 liam cage 完成的
You need to remove any adhesive residue and apply a new strip of adhesive on front panel for it to adhere to the aluminum frame.
Pre-cut adhesive strips can be bought from various retailers online or in store, google "iPad mini adhesive strips"
由 Gorilla 完成的
Thank you for all the replies. It is the LCD problem and I have already replaced it. My gadget works perfectly fine now. Umm... I am eternally grateful.
由 liam cage 完成的
