跳转到主内容
加入维修社区 - 创建账户
Apple 的第三代智能手表,配备可选的蜂窝网络功能,发布与2017年9月22日。
Black foil on OLED display damaged
As my top glass on the Apple Watch 3 broke, I ordered a new digitizer. When I removed the glass from the display, I damaged a black foil on the OLED display at the edges. The display is still working, but there are bright areas, where the foil is missing. What kind of foil is on the display? Can I replace it? Where to buy?
Update (01/06/2019)
The display looks like this now (glass removed, dark foil damaged):
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
3个答案
最有帮助的答案
Its polarizer film. And for the apple watch it is very dark in contrast. Done plenty using the warming burner on my stove with laptop tape. Perfect removal everytime. I would suggest using Samsung's polarizer sheet as a replacement. Trim to fit and use loca glue to attach and loca for
这个答案有帮助吗?
得分 2
添加一条评论
While I know you don’t want to hear it… I would just replace the full display assembly Apple Watch (38 mm Series 2) Screen or Apple Watch (42 mm Series 2) Screen
Replace a screen compatible with 42 mm Series 2 Apple Watch models A1758 and A1817. OLED Display. Front Glass Touch Sensitive Digitizer.图片
产品
$119.99
Replace a screen compatible with Apple Watch 38 mm Series 2 Models A1757 and A1816 smartwatches. Includes all of the small parts preinstalled in the assembly. OLED Display and Front Glass Touch Sensitive Digitizer.图片
产品
$99.99
这个答案有帮助吗?
得分 1
3条评论:
I have a series 3 watch. As the OLED display is still working (also in the areas, where the foil is missing), why should I buy a complete new display? If I can replace the black foil (is it a polarizer?), it will work again. If I can‘t replace the dark foil, I will glue the display to the new digitizer as it is. There will just be some brighter areas, where the foil is missing. Most important is, that the watch is working again as it is useless without the touchscreen.
完成的
I've never succeeded in repairing the screen.
Which is why I don't even try any more and just replace the full assembly.
完成的
I have the same problem. Did you find the foil?
完成的
添加一条评论
When the you removed black film, did you damage the gold foil in-between the polarizing film and LED display?
这个答案有帮助吗?
得分 0
2条评论:
Hey, I damaged the Gold foil and wanted to ask for what exactly it is for because my touch is still working in the areas where I do have black foil.
完成的
Its the force touch ring. If you're on watchOS 7, don't worry about it. Apple removed the feature.
完成的
添加一条评论
添加你的答案
Michaber 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 17
过去 30 天: 43
总计 2,017
