跳转到主内容
This is an HP Deskjet 1000 printer which was released in 2010, and can be identified by model number VCVRA-1003.
I need help on the printer
i dont know whats wrong with the printer its not letting the paper go though it so it gets jam in side
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
paper jam now cannot remove paper tray
完成的
添加一条评论
1个答案
Hey Nelson,
Make sure there are no foreign objects that may be in the tray.
Make sure the paper is being loaded correctly
Check to see that the rollers are clear of debris
Open and close the access door to make sure it is fully closed
Make sure you aren’t over loading the tray
Hope this helps a bit
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
nelsonwayne2012 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 6
总计 130
