跳转到主内容
加入维修社区 - 创建账户
苹果第三代智能手表,可选蜂窝网络版本,于2017年9月22日发布。
Water damaged Apple Watch
I went out for a run, took my watch off because it died and I put it in my pants pocket. I washed those pants and now the screen is cracked and has water damage. It will not turn on. I’ve tried everything. Is there any possibility that my watch could be fixed and if so what would it cost? It’s a Series 3 I believe.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
3条评论
My Apple Watch died while I was inside the Pool and now is full of water inside how would I fix this ?
由完成的
Hi my Apple Watch died too but I washed my hands my screen was already cracked and it stopped there got soap and water on the display and if I’m super unlucky it will be in the battery or logic board too I want to repair it by myself but idk what is broken or what to do someone I need advise and some thoughts if it’s riviveable
由完成的
Same thing happen to my Apple Watch. Did you have to replace everything or just a few different parts?
由完成的
添加一条评论
2个答案
最有帮助的答案
If you believe it has water damage, you must disassemble and clean it using at least 91% isopropyl alcohol, (you can use this Apple Watch Series 3拆解 to do that) make sure to scrub everything with a toothbrush.
more details on water damage can be found here: Electronics Water Damage
It is a tough repair, but as long as you follow the instructions you should be fine.
这个答案有帮助吗?
得分 9
1条评论:
I went to the beach and I didn’t lock my Apple Watch and now the brightness is red and I can barely see or know where things are, hoe can I fix it?
由完成的
添加一条评论
I was scuba diving and found a Apple Watch and I want to see if it can be fixed
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Breniecia Camphor 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 43
总计 38,112
