跳转到主内容
加入维修社区 - 创建账户
2015年发布的惠普 Pavilion 笔记本电脑系列。相比后期的 15-x 系列机型,15-p 的维修难度更高。
Certain Keys On Keyboard Are Unresponsive
My HP Pavilion 15-e013TX’s built-in keyboard has some keys unresponsive (A,S,D,F,J,K & L to be specific) I tried most of the things on https://au.pcmag.com/how-to/9345/how-do-... but the problem still prosper.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Most of these are because the keyboard has failed or the connector is loose. It may work again if you reconnect the keyboard internally, but it’s generally due to a matrix failure.
In your case, you picked the wrong system :-). The 15-e has a modular keyboard, which isn’t the case on the 15-p series. Refer to the Service manual to replace the keyboard and get the part number that matches the country you are in. The US part numbers are 719853-001 or 720597-001.
这个答案有帮助吗?
得分 2
添加一条评论
You will have to change all the Keyboard
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
FAMASyCoyote 358 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 28
总计 558
