跳转到主内容
加入维修社区 - 创建账户
Bose Wave Radio AWR1-1W(又称 Bose Wave Radio I)于 1993 年发布。这是一款桌面式 AM/FM 收音机系统,配备高性能立体声调谐器和两个独立闹钟。
My cd player not working properly
HI I have a bose model AWRCC1 I am having problems with my cd player. I have used a lens cleaner with brushes to clean it It will work for a cd and as soon as I put in another cd it will start to skip again. Can you give me some advice please or recommend someone to repair it . I live in Niagara Region Ontario Canada thanks Benny
回答此问题 我也有这个问题
这是一个好问题吗?
得分 7
2条评论
I have a Bose Wave which cd player does not work. When I put it, reads but shows the message “Not Playable”. I have tried everything: clean the lens, unplug for cord, reset, tried to plug away from electronic devices. Literally EVERYTHING!!! Radio is good, no problem. Interesting used to work very well. Someday started not reading the CDS. I have brand new ones and does not wok.
What else I can do before smash this sound, which I love… ;-(
由完成的
How to increase brightness on visual display?
由完成的
添加一条评论
1个答案
最有帮助的答案
The brush may remove any dust on the lens, but there is often a film as well. Use a cotton swab with some alcohol and gently clean the lens. Do not apply too much pressure as the lens is held in place with very fine wires. If the brush helps to allow a CD to play, the cleaning should be a bit more effective.
Report back with the results of the cleaning.
Dan
这个答案有帮助吗?
得分 3
2条评论:
Cleaning the lens w/ rubbing alcohol on a soft cloth fixed the problem! The CD player works perfectly. Thank you, thank you, thank you.
由完成的
I have the simular problem and it still does not play any CD's
由完成的
添加一条评论
添加你的答案
mbdalessio 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 16
过去 30 天: 89
总计 8,284
