跳转到主内容
Repair guides and troubleshooting for the Acer Aspire 5, a series of laptops on the Windows OS by Acer.
Built in camera not working.
Why built in camera is not working? I can not find acer Cristal clear in laptop even drive please help me.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
11条评论
Download this app: https://www.microsoft.com/en-us/p/window... and see if it works. I'm guessing you just uninstalled the software.
完成的
Forget about that app. Go to this site https://www.onlinemictest.com/webcam-tes... click the black box with the play button and click allow on the browser prompt asking to use your webcam. If it works, everything is fine, if not keep going.
Open you device manager and see if you see anything under "imaging device". If you find something right click - uninstall. Then reboot. If still not working do it again but click uninstall and check "delete driver" and reboot again.
After doing the above or if there is no Imaging Device go to the Acer site and find your PC model and locate the drivers for the webcam to reinstall.
完成的
Its doesn't showing any imagine device.
完成的
@spillz I cannot recommend that if you need to install a driver. as for shyam, When did this happen? did you reinstall windows? delete something?
完成的
No i upgrade it from win 8 to win 10,
完成的
显示更多的6条评论
添加一条评论
1个答案
已选择的解决方案
Go to the Acer website and see if you can find a Win10 camera driver for your model. You’re surely not the only Acer owner who’s upgraded from 8 to 10.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
shyam KARKI 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 14,068
