跳转到主内容
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
1041 个问题 查看全部
Why is my mobile data not working at times?
My iphone 6s plus mobile data sometimes work sometimes doesn’t work properly and i tried different sim provides but the issue is same my wifi is working fine but my mobile data sometimes doesn’t work at all and when it works it speed is very low sometimes when it doesn’t work i have to restart various times then it works please help me guys i have break my head alot into this but can’t do much did everything reset network settings & updated ios reset device did everything then too i am fade up with cellular thing please help me guys i really need your help
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Was the phone ever bent or did it suffer bad accidental drops ?
完成的
Never bro it wasn't bent ever
完成的
添加一条评论
3个答案
已选择的解决方案
you may like to check your network coverage or outages. Depending on where you are in the world you may just be unlucky enough to be in areas with poor 3g coverage. Ask friends/colleagues if they are having the same problem?
If it is not the sim, not the network coverage then it may be the antenna needs replacing
iPhone 6s 左上方的Wi-Fi天线更换
这个答案有帮助吗?
得分 2
1条评论:
Okay bro i ll go for antenna replacement
完成的
添加一条评论
此回答最初是针对另一个问题
I got exactly the same issue with a 6s I had been given to repair some time back, but I have to admit that I regrettably had to decline it after some testing…it’s not a typical 6s failure and when a component gives troubles just after a certain amount of time is very hard to diagnose even with proper tools. I hope someone more knowledgeable could give some insight, but consider the time/reward ratio sometimes fights against a component level repair.
这个答案有帮助吗?
得分 2
添加一条评论
Mobile data is provided by the mobile operator with whom you have a contract, ask first.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ahmed Ghosi 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 14
总计 139
