跳转到主内容
问题已关闭
Why is my mobile data not working guys?
I am using 6s plus my mobile data only works for 5 minutes and then it stops and when i toggle my airplane mode from off to on again it starts and works for 5 mins and then it stops what could be the reason please help
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
I got exactly the same issue with a 6s I had been given to repair some time back, but I have to admit that I regrettably had to decline it after some testing…it’s not a typical 6s failure and when a component gives troubles just after a certain amount of time is very hard to diagnose even with proper tools. I hope someone more knowledgeable could give some insight, but consider the time/reward ratio sometimes fights against a component level repair.
这个答案有帮助吗?
得分 2
添加一条评论
最有帮助的答案
you may like to check your network coverage or outages. Depending on where you are in the world you may just be unlucky enough to be in areas with poor 3g coverage. Ask friends/colleagues if they are having the same problem?
If it is not the sim, not the network coverage then it may be the antenna needs replacing
iPhone 6s 左上方的Wi-Fi天线更换
这个答案有帮助吗?
得分 2
1条评论:
Okay bro i ll go for antenna replacement
完成的
添加一条评论
此回答最初是针对另一个问题
Mobile data is provided by the mobile operator with whom you have a contract, ask first.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 42
