Flashing light on handset
The red light on all handsets is flashing and there is a rapid beep as dial tone. Can still ring out and receive calls . We dont have telstra message bank activated
Hi @tina51 ,
What is the model number of your phone?
If it is a Uniden Dect 1760 to turn off the light:
With the phone in standby, open the menu and select Global Setup; select VMWI Reset, then select Yes.
Is the phone connected as a VOIP phone service on the NBN?
If it is then are you sure that Messagebank hasn’t been turned On? By default Telstra turns on Messagebank when on the NBN.
What do you get when you dial 101?
这个答案有帮助吗?
Thanks so much. Going to global set up fixed it . Yay. Thanks for thatt
dect 6,0 uniden
Unfortunately that's not the model number. It's the signalling protocol used by the phone.
The model number can be found on the bottom of the base station or sometimes under the battery in the phone
Press and hold the FIND button about five to ten seconds until the beeping stops.
You can also try clearing all incoming calls.
这个答案有帮助吗?
there is no FIND button on the menu?????
How do I delete messages...and stop the explitive phone from continuously from flashing?????
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 58
总计 27,567
2条评论
where is the find button
由 Rhonda Pollard 完成的
@rhondapollard
Please confirm the model number of your phone?
由 jayeff 完成的
