跳转到主内容
A1706/EMC 3071—于2016年11月上市,这台13''MacBook Pro带有OLED触摸条。以双核“Skylake”英特尔酷睿i5 CPU和4个雷电3端口为特征。
239 个问题 查看全部
How do I make the second monitor active if primary is down
Normally I would use Command F1 to make the external monitor active but there is no F1 key on the touch bar. Also the screen is broken so i can’t get into system preferences on the primary display. Need to turn off autoboot before putting new display on.
@danj
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
8条评论
Won't removing the battery prevent the Mac from turning on whilst repairing it?
完成的
see step #1 Step 1 Disable Auto Boot on this guide. Just trying to follow directions
2016后期带Touch Bar的13寸MacBook Pro 显示屏组件更换
完成的
I got the bottom off without activating the power on. Not easy!
完成的
@mayer I'm at a loss of understanding that removing the lower case could trigger the fastboot?
完成的
Obviously somebody did it or it wouldn't be in the guide. Lots of things get put in guides because someone had to first do it wrong.
完成的
显示更多的3条评论
添加一条评论
1个答案
已选择的解决方案
I just spoke with an Apple employee over the phone and she said that if you disconnect the battery before doing anything else you should be fine and fastboot shouldn’t be triggered. Someone is going to lose their job… LOL
这个答案有帮助吗?
得分 1
4条评论:
If you did that much of a favor for me, I'd say NOTHING to protect your job. Don't give their name out.
If you want to get anywhere, sometimes you need to protect people who give you the info you shouldn't get.
完成的
@nick I was in utter shock that this particular employee gave me this information, I'd have to say. Before hanging up with that employee I told her that "iFixit thanks you" and "you are the type of person working for Apple that is actually helpful when it comes to technical support".
完成的
She's probably tired of Apple's crap. That's probably why you got that info.
完成的
Personally I am too. It's just a matter of time before the T2 chip completely locks down Macs from being user-servicable. I am dreading that fateful day that someone comes across this forum asking why their Mac won't boot after a modification to an internal part.
完成的
添加一条评论
添加你的答案
mayer 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 16
总计 319
