How do I make the second monitor active if primary is down
Normally I would use Command F1 to make the external monitor active but there is no F1 key on the touch bar. Also the screen is broken so i can’t get into system preferences on the primary display. Need to turn off autoboot before putting new display on.
8条评论
Won't removing the battery prevent the Mac from turning on whilst repairing it?
由 [deleted] 完成的
see step #1 Step 1 Disable Auto Boot on this guide. Just trying to follow directions
2016后期带Touch Bar的13寸MacBook Pro 显示屏组件更换
由 mayer 完成的
I got the bottom off without activating the power on. Not easy!
由 mayer 完成的
@mayer I'm at a loss of understanding that removing the lower case could trigger the fastboot?
由 [deleted] 完成的
Obviously somebody did it or it wouldn't be in the guide. Lots of things get put in guides because someone had to first do it wrong.
由 mayer 完成的
显示更多的3条评论
