跳转到主内容
Released in March 2016, the 80D is the successor to the 70D, featuring a newly developed 24.2 megapixel APS-C sensor.
What is this part of the LCD screen called? (Canon 80D)
Hi everyone, I recently dropped my 80D on the grass, it had the LCD screen open, and luckily, it keeps working fine, but now doesn’t let me pull it out, as the “rotating” part broke (see photo).
As the screen itself keeps working perfectly well, I was hoping maybe I could get somewhere just this “mount” part, instead of changing the whole thing?
Couldn’t find this replacement part or at leas it’s name anywhere (neither could I find the whole screen kit with this base). Could anyone help?
Thank you very much in advance,
Alex
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Looks like a compression fitting to me. Put the back into place and see if you can press it on.
这个答案有帮助吗?
得分 2
添加一条评论
@geofocker that is simply called a hinge. Amazingly enough it does not appear to be readily available and when one can be found it is costly like on here
这个答案有帮助吗?
得分 2
1条评论:
Thank you very much! It is, indeed, what I've been looking for. And yes, it seems a bit costly, but, will give it a try :)
完成的
添加一条评论
添加你的答案
Alex Krotkov 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 12
总计 572
