跳转到主内容
The first generation of the Chevrolet Equinox, a crossover SUV from Chevrolet based on General Motors' Theta platform.
114 个问题 查看全部
Oil pressure low turn off engine
My 2011 chevy equinox oil pressure low turn off engine sign apered on my dash board then weird noise from engine and smoke was coming out the hood turn it off poped the hood open all my oil leaked out from bottom checked dip stick and it was dry know it dosent turn on.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
@tony209
all of this “engine sign apered...then weird noise from engine... smoke was coming out...all my oil leaked out from bottom...now it doesnt turn on” sounds like a seized engine. There are just to many things going on for us to even come up with a single solution. you can try and remove the spark plugs, add oil to the engine and then try to turn the engine by hand using a socket wrench on the crankshaft nut. If you can still turn the engine it may get repaired, if you cannot turn it, it most likely seized up on you. Let us know what you find out
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Antonio Hernandez 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 641
