跳转到主内容
加入维修社区 - 创建账户
Canon EOS Rebel T5 是一款于 2014 年 2 月发布的 1800 万像素数码单反相机。它也被称为 EOS 1200D 和 EOS Kiss X70。
Flashing Yellow light in front of camera
Yellow light flashing on front of camera and will not let me take a picture. Pop-up flash kept hitting hat brim and eventually stopped working. This is for my EOS Rebel T5 1200D
I have removed the battery and that did not solve the problem.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
I know that you probably aen’’t having this problem anymore but I also had it and figured out that I had accidentally turned on the timer on my Rebel t6. The yellow light should blink for about ten seconds before taking a picture. To turn this off (on the t6) click on the left button next to the set button and then select “single shooting”. I hope that helps!
这个答案有帮助吗?
得分 5
5条评论:
Thank you so much !! It helped me
完成的
It helped me too, thanks buddy
完成的
Thank you! That totally fixed it. God bless you!
完成的
Posted photos on my answer to confirm this, checked on a T6i.
Essentially the T6i is the full fat version of your T6.
完成的
I made an account so fast and even screwed up my name just to say thank you for this. I've been photographing all my life and a rookie mistake almost sent me into a spiral because I'm in a rush
完成的
添加一条评论
What does it do when you try to take a picture? Specifically, at what point does it stop? Does the lens autofocus (if you have an autofocus lens for it)? Do any of the viewfinder lights come on? And what shooting mode are you in?
The flash thing is weird. It shouldn’t have stopped working just from hitting the brim of your hat. Have you tried turning flash off and making sure it’s not set to auto flash?
这个答案有帮助吗?
得分 0
添加一条评论
It's the self timer mode.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Neil Fox 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 48
总计 8,792
