跳转到主内容
加入维修社区 - 创建账户
Canon AE-1 是一款用于可更换镜头的 35 mm 单镜头反光 (SLR) 胶片相机。
How to replace Battery contacts?
Hi!
I bought an old A1. It doesn‘t fire. I think it´s because the battery contacts corroded. I already tried to clean it with alcohol but no chance. Is there a possibility to get to the battery contacts. Maybe to replace them or to remove it and put it into alcohol overnight.
Greetings
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Alcohol is not what I would use as it won’t cut through the battery corrosion. What you need is white vinegar use a cotton swab (Q-Tip) dipped in the vinegar and hold it against the contacts. You also need to flush the vinegar with water using the same approach using a wet cotton swab.
The bottom contact has a spring to push it up to make contact to the battery if this is not working you’ll need to replace the battery holder. Its a bit of work! Its not something I would recommend for a first timer as its a delicate job. Here’s the Canon A-1 service manual jump down to the exploded views at the end there you’ll see whats involved to get to it. You basically need to take the whole camera apart.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Lucas 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 38
总计 2,899
